[GRASS-dev] r.watershed and swap memory
Glynn Clements
glynn at gclements.plus.com
Wed Mar 19 01:12:56 EDT 2008
Hamish wrote:
> > yes r.terraflow goes to /tmp, that is considered a bug to me, not an
> > enhancement...
> > The location from which we have the GRASS dataset is generally the
> > best guess for large empty Disk space.
> note these r.terraflow options:
> STREAM_DIR Location of intermediate STREAMs
> default: /var/tmp
This should be in lower case. AFAICT, we never use upper case in
option names.
