[GRASS-dev] [GRASS GIS] #102: new tabs in GUI have required last
trac at osgeo.org
Wed Mar 19 00:21:33 EDT 2008
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: unspecified
Keywords: |
Someone went through and added new tabs to several of the module interface
sections. This is nice. However, in the couple I've run into (e.g.
r.colors and v.in.ascii), the "required" tab is the bottom one on the
stack and rightmost tab. That is the stuff that is most important is the
most hidden. Also v.in.ascii required output vector name is in the options
section, not the required section, and while the input raster name for
r.colors is in the required section, its description says it is optional.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/102>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
