[GRASS-dev] GRASS 6.3.0
Markus Neteler
neteler at osgeo.org
Wed Mar 19 08:56:32 EDT 2008
On Tue, Mar 18, 2008 at 1:52 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Martin Landa wrote:
> > > There are a lot of other script fixes not backported to 6.3.0, mostly
> > > bulk quoting of variables. I didn't backport them as I have not
> > > individually tested the changes and so don't guarantee they are no
> > > introduced typos. These will help with the spaces in pathnames problems,
> > > which are mostly a MS Windows phenomenon. I did not systematically quote
> > > everything, so it is almost certain that there will be more unquoted path
> > > and file names. These fixes might be nice to get out to MS Windows users
> > > in a 6.3.1 after more testing in SVN/trunk. Probably easier to cut a new
> > > 6_3_1 branch from the main grass6 line than to bother backporting things
> > > to 6.3.0's branch.
> > Hm, creating branch for 6.3.1 seems to be a bit complicated to me. I
> > would prefer releasing 6.3.0, creating branch for 6_4 (trunk for 7.x).
> > Releasebranch_6_3 used for 6.3.1 (after tagging 6.3.0) as usually.
> I would suggest keeping with releasebranch_6_3 for 6.3.1 (if it
> occurs).
I agree. That's the most cost effective way.
> If you were planning on a release which (roughly) corresponds to the
> current trunk, that should probably be 6.4.0. The differences between
> 6.3.1 should consist only of changes which have been vetted and deemed
> necessary.
This corresponds to the graph in
http://trac.osgeo.org/grass/wiki/Grass7Planning
Proposal
End of this month:
* Get out 6.3.0final (releasebranch_6_3)
* Immediately branch off 6.4.0 to releasebranch_6_4
* rename trunk to 7.0.svn
Markus
