[GRASS-dev] GRASS 6.3.0
Martin Landa
landa.martin at gmail.com
Fri Mar 21 06:57:58 EDT 2008
Thanks Glynn, I backported your fixes to releasebranch_6_3.
Martin
2008/3/21, Glynn Clements <glynn at gclements.plus.com>:
> Markus Neteler wrote:
> > I found that
> > gui/wxpython/vdigit/
> > fails on
> > make -j4
> > Something needs to be serialized there.
> Fixed in SVN:
> -default: $(SHLIB) install_vdigit
> +default: install_vdigit
> -install_vdigit:
> +install_vdigit: $(SHLIB)
> $(INSTALL_DATA) _grass6_wxvdigit.so $(ETCDIR)/vdigit/
> $(INSTALL_DATA) grass6_wxvdigit.py $(ETCDIR)/vdigit/
> Note to anyone writing Makefiles: a dependency line such as:
> target: source1 source2
> states that source1 and source2 must be built before running the
> commands for the rule. It does not require that source1 and source2
> are built in that order. Although that will typically be the case for
> a single-threaded build, a parallel build will attempt to build
> source1 and source2 concurrently.
> If source1 needs to be built before source2, this must be expressed through
> dependencies, e.g.:
> target: source2
> source2: source1
> Another problem with vdigit: the C++ wrapper file grass6_wxvdigit_wrap.cpp
> is *not* a source file (it is built from the .i files using SWIG), and
> should not be stored in the SVN repository. It should be generated by SWIG
> during the build process.
> However, this also lacks correct dependency information. First,
> grass6_wxvdigit.i doesn't list the various .i files as dependencies,
> so it won't be re-built if one of them is modified. Secondly, the rule
> which generates grass6_wxvdigit_wrap.cpp doesn't actually have that
> file as a target, so it won't get run if the file needs to be
> re-built.
> Finally, while writing this, I've just noticed that gui/wxpython/Makefile
> has:
> default: install_scripts parsubdirs
> which will run both targets concurrently. This is theoretically
> problematic, as vdigit/Makefile assumes that the etc/wxpython/vdigit
> directory has already been created. In practice, you'll get away with it,
> as the chances of compiling the entire vdigit module before a mkdir
> command has completed are essentially nil.
> However, to avoid setting a bad example which may cause actual problems if
> someone follows it, I've changed the rule to:
> $(MAKE) parsubdirs
> Note that parsubdirs is a "phony" target, so the following *won't* work:
> default: parsubdirs
> parsubdirs: install_scripts
> Okay, I was wrong about the "finally" above; I've also changed:
> - $(INSTALL_DATA) _grass6_wxvdigit.so $(ETCDIR)/vdigit/
> + $(INSTALL_DATA) $(SHLIB) $(ETCDIR)/vdigit/
> as the suffix won't be ".so" on all platforms.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
