[GRASS-dev] GRASS 6.3.0
William Kyngesburye woklist at kyngchaos.com
Fri Mar 21 09:49:48 EDT 2008
On Mar 21, 2008, at 1:29 AM, Glynn Clements wrote:
> Another problem with vdigit: the C++ wrapper file
> grass6_wxvdigit_wrap.cpp
> is *not* a source file (it is built from the .i files using SWIG), and
> should not be stored in the SVN repository. It should be generated
> by SWIG
> during the build process.
Correct or not, I'vee seen it as a convention in many projects to
include pre-SWIG'd sources (ie Mapserver, Qgis, GDAL).  While
developers may be OK with adding SWIG to their toolbox (though I
haven't installed it on my new Mac because I don't need it any more),
users who build from source may not have SWIG, and may not want to
install something that's not used at runtime but only for compilation.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
