[GRASS-dev] r.watershed and swap memory
ivan marchesini marchesini at unipg.it
Sun Mar 23 12:14:09 EDT 2008
hmmm
thanks to Helena for the suggestion of use accumulation map and then
r.mapcalc (I knew this method but I didn't remember it  :-(  )
the problem is that, also using this method, the ram wasn't enougth..
at the moment we have solved using another PC (13 GB of RAM)... and the
process is still running... after 3 days...
but if I will find alternatives I will let you know...
many thanks to all...
Il giorno mer, 19/03/2008 alle 15.29 -0700, honegger ha scritto:
> just looking for a code that's able to process a 50'000x60'000 grid.
> streamflow sounds verz promising, but as it's only availible as a binary
> it's not really usable within linux (as you would need exactly the same
> specs..)
> r.watershed is rather slow and terraflow isn't an option because of the
> inscalability of the basin size.
> has anybody other options or experiences?
> hamish_b wrote:
> >> > note these r.terraflow options:
> >> >     STREAM_DIR   Location of intermediate STREAMs
> >> >                  default: /var/tmp
> > Glynn:
> >> This should be in lower case. AFAICT, we never use upper case in
> >> option names.
> > another task for GRASS 7....
> > H
> > ____________________________________________________________________________________
> > Never miss a thing.  Make Yahoo your home page.
> > http://www.yahoo.com/r/hs
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73 at jabber.org
