[GRASS-dev] r.watershed and swap memory
Luca Casagrande luca.casagrande at gmail.com
Wed Mar 26 19:49:42 EDT 2008
Hello everybody.
While Ivan is working on r.watershed I am trying to reach the result using
TerraSTREAM.
With the help of Thomas, I have successfully created a drainage map from the
DEM and the idea is to use it
with r.water.outlet. The problem is that it needs a drainage map with values
that run from -8 to 8, instead TerraSTREAM prompt out a bitmap (using SFD)
or a raster with values from 0 to 360 degree (with MFD). I can reclass it
with r.reclass
but I don't know how handle negative values.
Any suggestion on this?
Thanks
Luca
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080327/afb321ee/attachment.html
