[GRASS-dev] g.mapsets, print only accessible mapsets
Martin Landa landa.martin at gmail.com
Mon Mar 24 08:35:54 EDT 2008
the attached patch adds to g.mapset module new flag '-l' (print
available mapsets with write permission). It requires dummy value for
mapset, e.g.
g.mapset -l map=dummy
same story like `r.in.gdal -f` and others. It would be reasonable to
introduce new attribute in option/flag structure, something like
'suppress_required'. The value could be global (YES/NO), to suppress
all required flags/options or better list of option/flags (e.g. their
keys) which are required and will be suppressed by the given
flag/option.
Regards, Martin
2008/3/21, Glynn Clements <glynn at gclements.plus.com>:
>  Martin Landa wrote:
>  > >  > is there a way how to determine if a mapset is accessible without need
>  > >  > to switch 'g.mapset name' -> 'ERROR: You don't have permission to use
>  > >  > this mapset'. If not maybe new flag for g.mapsets would make sense?
>  > >  > -a 'List all accessible mapsets'
>  > > At the C level, G__mapset_permissions() and G__mapset_permissions2()
>  > >  determines whether or not a specific mapset can be used as the current
>  > >  mapset (i.e. it's a directory, and you own it).
>  > >  AFAIK, there isn't a user command to determine this. If it's useful,
>  > >  it really belongs in g.mapset rather than g.mapsets, as the former
>  > >  deals with the current mapset (used for output) while the latter deals
>  > >  with the mapsets used for input.
>  > I think it would be useful, at least for creating list of mapsets in
>  > GUI start-up screen. Currently is used 'g.mapsets -l' which prints all
>  > mapsets in the location. I don't fully understand here, why g.mapsets
>  > is not good place for that.
> "g.mapsets -l" displays a list of mapsets which are suitable for use
>  as values in g.mapsets' mapset= and addmapset= options.
>  You are essentially asking about mapsets which are suitable for use as
>  values in the mapset= option of g.mapset[1]. The logical place for
>  such an option is in g.mapset.
>  [1] init.sh/init.bat have their own built-in clone of g.mapset. It
>  would be worth looking into whether they can be changed to use
>  g.mapset instead.
>  There is a great deal of asymmetry between output and input; the
>  current mapset and the mapset search path are really very different
>  entities. g.mapset deals exclusively with the former, g.mapsets deals
>  exclusively with the latter.
>  And the option which you're proposing is related to the former.
>  > g.mapsets -l -> prints *all* mapsets
>  > g.mapsets -a -> print only *accessible* mapset
> "accessible" is the wrong word here. You can "access" any mapset for
>  which you have read permission.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080324/8ecdb8da/g-mapset-l.bin
