[GRASS-dev] G__create_alt_search_path() bug?
Tue Mar 25 01:53:28 EDT 2008
Martin Landa wrote:
> I found strange construction in G__create_alt_search_path()
> 114 	    return 0; /* ??? */
> 115
> 116 	    get_list_of_mapsets();
> see
> http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/mapset_nme.c?rev=30718#L107
> I guess that get_list_of_mapsets() should be called before return.
It doesn't actually need to be called at all. Setting nmapset to 0
will cause get_list_of_mapsets() to be called the next time that the
mapset list is queried.
