[GRASS-dev] G__create_alt_search_path() bug?
Martin Landa landa.martin at gmail.com
Tue Mar 25 06:03:42 EDT 2008
2008/3/25, Glynn Clements <glynn at gclements.plus.com>:
>  > I found strange construction in G__create_alt_search_path()
>  > 114       return 0; /* ??? */
>  > 115
>  > 116       get_list_of_mapsets();
>  > see
>  > http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/mapset_nme.c?rev=30718#L107
>  > I guess that get_list_of_mapsets() should be called before return.
> It doesn't actually need to be called at all. Setting nmapset to 0
>  will cause get_list_of_mapsets() to be called the next time that the
>  mapset list is queried.
applied in trunk
http://trac.osgeo.org/grass/changeset/30726
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
