[GRASS-dev] g.mapsets, print only accessible mapsets
Martin Landa
landa.martin at gmail.com
Tue Mar 25 05:57:36 EDT 2008
2008/3/25, Glynn Clements <glynn at gclements.plus.com>:
> > thanks, small issue here -- the '-l' flag ignores gisdbase= and
> > location= parameters, it always prints list of mapsets for the
> > *current* location. The attached patch should fix it. If you have no
> > objections I will applied in trunk.
> I'm not sure that a separate function with gisdbase/location arguments
> is necessary. It is sufficient for g.mapset to just change those
> settings with G__setenv().
applied in trunk
http://trac.osgeo.org/grass/changeset/30725
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
