[GRASS-dev] Re: [GRASS GIS] #104: saving display to tiff or ppm
garbled when NVIZ is not top window
trac at osgeo.org
Thu Mar 27 20:38:26 EDT 2008
#104: saving display to tiff or ppm garbled when NVIZ is not top window
Reporter: dylan | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: NVIZ openGL
Comment (by glynn):
Replying to [comment:8 msieczka]:
Nothing out of the ordinary there.
The context, Pixmap and GLXPixmap are all being created with respect to
the same XVisualInfo* value.
The GLXPixmap case works fine on Cygwin's XWin.exe, X.org with "nv"
driver, and X.org with "nvidia" driver (the first two with X.org's libGL,
the last with nVidia's). This is with X.org 7.2 & server 1.3.0.0.
This is looking like an issue with the Radeon driver.
Note that we handle the case where the server fails to create the
GLXPixmap. The problem is that it creates the GLXPixmap then complains
when you try to use it.
One finale check: can you try "export LIBGL_DEBUG=verbose" before running
it, and see if that sheds any light?
Ticket URL: <http://trac.osgeo.org/grass/ticket/104#comment:9>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
