[GRASS-dev] Re: [GRASS GIS] #104: saving display to tiff or ppm garbled when NVIZ is not top window
GRASS GIS trac at osgeo.org
Fri Mar 28 05:49:59 EDT 2008
  Reporter:  dylan    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:  NVIZ openGL
Comment (by msieczka):
 Replying to [comment:9 glynn]:
 > One finale check: can you try "export LIBGL_DEBUG=verbose" before
 running it, and see if
 > that sheds any light?
 It doesn't seem to. The only difference is that now, at NVIZ startup, it
 prints additionaly:
 libGL error:
 Can't open configuration file /etc/drirc: No such file or directory.
 libGL error:
 Can't open configuration file /path/to/my/home/.drirc: No such file or
 directory.
 Does it matter?
 I can't get vesa driver to work (X starts but terminates right away
 without errors or significant warnigs in the log file). If time allows
 I'll try fglrx and post the results then.
Ticket URL: <http://trac.osgeo.org/grass/ticket/104#comment:10>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
