[GRASS-dev] Current state of wxPython GUI
Michael Barton michael.barton at asu.edu
Fri Mar 28 02:24:21 EDT 2008
On Mar 27, 2008, at 1:29 PM, grass-dev-request at lists.osgeo.org wrote:
> Message: 4
> Date: Thu, 27 Mar 2008 17:47:11 +0100 (CET)
> From: benjamin.ducke at ufg.uni-kiel.de
> Subject: Re: [GRASS-dev] Current state of wxPython GUI
> To: grass-dev at lists.osgeo.org
> Message-ID:
> 	<48002.195.72.173.148.1206636431.squirrel at webmail.mail.uni-kiel.de>
> Content-Type: text/plain;charset=iso-8859-1
>>>  IndexError: list index out of range
>> should be also fixed in trunk now
> OK, that works now.
>>>  2. The GRASS init shell script now dumps this message twice to the
> console:
>>>  "To run a command as administrator (user "root"), use "sudo
>>> <command>".
>>>  See "man sudo_root" for details."
>>>  I guess it attempts to run something with su privileges?
>> OK, I assume this is well-known 'sudo' behaviour issue on Ubuntu...
> I am only getting second thoughts that this means some important
> commands are not being run upon start-up on Ubuntu.
> Do you know which commands might cause these messages so I can look
> into it?
Benjamin,
Thanks much for testing. AFAIK, there is nothing in the GUI that is
run with su or sudo, and the wxPython GUI does not call any bash
shell script commands. So this is an odd error.
I'm real tied up at the moment (at the Society for American
Archaeology meetings and giving papers tomorrow), but hope to get a
chance to get back to working on the GUI with Martin in the next
month or so. I'll try to test for your error running i.group from the
georectifier. Does the rest of it work OK?
Important: What versions of Python and wxPython are you using?
Cheers
Michael
> Best,
> Benjamin
>> Martin
