[GRASS-dev] backporting help for SVN
Fri Mar 28 17:43:46 EDT 2008
William Kyngesburye wrote:
> >> A pair I haven't done yet (ran out of time this morning), that are
> >> companions to Glynn's r29926 and r30066, which were applied to the
> >> release branch:
> >> http://trac.osgeo.org/grass/changeset/30347
> >> http://trac.osgeo.org/grass/changeset/30704
> >> These affect some lib/init stuff, but are important to return what
> >> Glynn removed, in another form.  These also have worked well for me
> >> so
> >> far, and are in my binaries, and no reports of problems yet.
> >> Comments?
> > Platform-specific targets should be implemented using make
> > conditionals, rather than an unconditional target which performs the
> > test within the commands. IOW:
> OK, add this to the above list, to be backported (if OK) as a unit:
> http://trac.osgeo.org/grass/changeset/30773
One minor point:
	$(INSTALL) -m 755 grass-xterm-mac $(ETC)
Makefiles shouldn't hard-code the permissions. The user should be able
to override this by setting INSTALL. Typically. $(INSTALL) will use
755 while $(INSTALL_DATA) will use 644.
