[GRASS-dev] backporting help for SVN
William Kyngesburye
woklist at kyngchaos.com
Sat Mar 29 11:03:27 EDT 2008
Oh, looks like all the installs there hardwired the -m 755 flag. I'll
let you take care of cleaning up the init makefile if you want.
On Mar 28, 2008, at 4:43 PM, Glynn Clements wrote:
> One minor point:
> $(INSTALL) -m 755 grass-xterm-mac $(ETC)
> Makefiles shouldn't hard-code the permissions. The user should be able
> to override this by setting INSTALL. Typically. $(INSTALL) will use
> 755 while $(INSTALL_DATA) will use 644.
> Glynn Clements <glynn at gclements.plus.com>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
