[GRASS-dev] Re: [GRASS GIS] #105: r.in.xyz: zscale parameter addition patch
GRASS GIS trac at osgeo.org
Sat Mar 29 14:10:14 EDT 2008
  Reporter:  neteler      |       Owner:  hamish
      Type:  enhancement  |      Status:  assigned
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:
Comment (by neteler):
 I would appreciate if you don't revert the -i flag. It's a major PITA to
 manually fix files as in the indicated case (with Lidar, you often have
 hundreds of tiles to process).
 The purpose that the elevation data comes in feet and you want it in
 meters or you want centimeters or whatever. Data often come in a different
 way than desired.
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/105#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
