[GRASS-dev] make install targets?
Markus Neteler
neteler at osgeo.org
Sun Mar 30 07:40:10 EDT 2008
(copied here from grass-user)
Related to below problem, would it be possible to add a
make install
target to all Makefiles? Then especially the GRASS Addons
installation would be greately simplified.
Markus
On Sun, Mar 30, 2008 at 12:57 PM, Gazz1982 <garynobles at yahoo.com> wrote:
> That doesn't seem to work,
> Here is my directory structure under grass
> bin
> bwidget
> docs
> driver
> etc
> fonts
> include
> lib
> scripts
> I copied the r.horizon2 folder into the bin directory and tried to make it
> it returned the same error
> I have superuser/root permissions
> I'm sure when i do it once I will be able to do it again and again!
> Thanks for your help
> there isn't an imagery or raster folder should I make one in the grass
> directory?
> Nikos Alexandris wrote:
> > On Sat, 2008-03-29 at 16:20 -0700, Gazz1982 wrote:
> >> I have just been converted to Linux after struggling with cgywin!
> >> How do I install a new grass module, in this case I have the file
> >> r.horizon2.tar.gz on my desktop and my $GISBASE is /usr/lib/grass
> > (You might need to be superuser/root to do "make install" in the end)
> > In general it must be something like:
> > 1. copy "add-on" directory to /where/your/grass/source/is under the
> > respective generic module category
> > e.g. for i.pr it would be:
> > cp -r i.pr /where/your/grass/source/is/imagery/
> > 2. configure grass
> > cd /where/your/source/is/
> > ./configure #with your parameters
> > 3. go to the "add-on" directory and "make it"
> > e.g.
> > cd /imagery/i.pr
> > make
> > 4. back to grass source directory
> > make install
> >> I've done this before but I can't remember the commands and where
> >> everything
> >> should go
> >> Thanks
> > Hope this helps (as it helped me once when somebody told me how make it)
> > Cheers,
> > Nikos
