[GRASS-dev] make install targets?
Sun Mar 30 13:09:35 EDT 2008
Markus Neteler wrote:
> (copied here from grass-user)
> Related to below problem, would it be possible to add a
>  make install
> target to all Makefiles?
There are many cases which would require a custom install target (as
opposed to a generic target in e.g. Rules.make), as a generic target
wouldn't know which files it's supposed to be installing.
Realistically, this should wait for 6.4/7.x, when the build system
will get cleaned up to make it easier to build modules against an
installed version of GRASS.
