[GRASS-dev] forking on OSX Leopard (or earlier for that matter)
William Kyngesburye woklist at kyngchaos.com
Sun Mar 30 12:28:36 EDT 2008
A change in OSX Leopard (10.5) that may affect GRASS, though I haven't
seen any problems yet.  From a release note for the developer tools:
CoreFoundation and fork()
Due to the behavior of fork(), CoreFoundation cannot be used on the
child-side of fork(). If you fork(), you must follow that with an
exec*() call of some sort, and you should not use CoreFoundation APIs
within the child, before the exec*(). The applies to all higher-level
APIs which use CoreFoundation, and since you cannot know what those
higher-level APIs are doing, and whether they are using CoreFoundation
APIs, you should not use any higher-level APIs either. This includes
use of the daemon() function.
Additionally, per POSIX, only async-cancel-safe functions are safe to
use on the child side of fork(), so even use of lower-level libSystem/
BSD/UNIX APIs should be kept to a minimum, and ideally to only async-
cancel-safe functions.
This has always been true, and there have been notes made of this on
various Cocoa developer mailling lists in the past. But CoreFoundation
is taking some stronger measures now to "enforce" this limitation, so
we thought it would be worthwhile to add a release note to call this
out as well. A message is written to stderr when something uses API
which is definitely known not to be safe in CoreFoundation after
fork(). If file descriptor 2 has been closed, however, you will get no
message or notice, which is too bad. We tried to make processes
terminate in a very recognizable way, and did for a while and that was
very handy, but backwards binary compatibility prevented us from doing
so.
If a process forks and a corefoundation unsafe function is used, you
get a warning in the console:
The process has forked and you cannot use this CoreFoundation
functionality
safely. You MUST exec().
Break on
__THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__
to debug.
This can quickly clog the console and log files.  While it doesn't
seem to affect GRASS, an improperly-built TclTk can cause trouble.  I
ran into this when testing NVIZ for the pixmap/pbuffer export bug.
I've updated the OSX Readme TclTk build example to include an extra
configure option:
--disable-corefoundation
Since the example is for an X11 TclTk build, CoreFoundation isn't
really necessary, so this is OK.
And, though the warning log problem is Leopard-only, the forking is
still a potential issue with earlier OSX versions, so this option
should be used for all OSX versions.
For a TclTk Aqua build (for those that are willing to brave other
problems), CoreFoundation is needed.  It is currently only partially
fixed in Tcl (8.4 and 8.5) - for 64bit only, though it also happens in
32bit mode.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
