[GRASS-dev] Re: [GRASS-user] modify feature's values interactively
Moritz Lennert
mlennert at club.worldonline.be
Mon Mar 31 08:12:38 EDT 2008
On 31/03/08 13:54, christian Brandt wrote:
>> Date: Fri, 28 Mar 2008 17:38:44 +0100
>> From: mlennert at club.worldonline.be
>> To: chrisbrandt74 at hotmail.com
>> CC: grass-user at lists.osgeo.org
>> Subject: Re: [GRASS-user] modify feature's values interactively
>> On 28/03/08 16:48, christian Brandt wrote:
>>> Dear Moritz,
>>> after implementation of wxPython GUI I started with a new grass
>>> session with the command grass63 -wxpython. Then the following
>>> message came up:
>>> grass63 -wxpython Cleaning up temporary files..... Starting GRASS ...
>>> Traceback (most recent call last): File
>>> "/usr/local/grass-6.3.0RC5/etc/wxpython/gis_set.py", line 28, in from
>>> gui_modules import utils File
>>> "/usr/local/grass-6.3.0RC5/etc/wxpython/gui_modules/utils.py", line 1
>> There must be more to the traceback, and the interesting part is always
>> at the end...
> SyntaxError: invalid syntax
> Error in GUI startup. If necessary, please
> report this error to the GRASS developers.
> Switching to text mode now.
> Hit RETURN to continue...
>> Also: it would be helpful if you could give the following info when
>> reporting issues with wxgrass:
>> - OS 10.2 64 bit
>> - python version 2.5
>> - wxpython version 2.5.2?
I'll leave this to the Mac OS X experts...
Moritz
