[GRASS-dev] [GRASS GIS] #110: db/drivers/dbf fail to build due to
undefined reference to 'SASetupDefaultHooks'
Martin Landa
landa.martin at gmail.com
Mon Mar 31 09:32:37 EDT 2008
2008/3/31, Glynn Clements <glynn at gclements.plus.com>:
> GRASS GIS wrote:
> > #110: db/drivers/dbf fail to build due to undefined reference to
> > Reporter: marisn | Owner: grass-dev at lists.osgeo.org
> > Type: defect | Status: new
> > Priority: critical | Milestone: 6.4.0
> > Component: default | Version: svn-trunk
> > Keywords: |
> > Revision: 30825
> > OS: Ubuntu 7.10 64bit
> > /home/dace/soft/grass_trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_shape.so:
> > undefined reference to `SASetupDefaultHooks'
> Those calls were added in the latest revision:
> r30804 | neteler | 2008-03-30 10:21:48 +0100 (Sun, 30 Mar 2008) | 1 line
> sync'ed to GDAL SVN-trunk: gdal/ogr/ogrsf_frmts/shape/
> They appear to be part of GDAL, so GDAL is now a dependency of the DBF
> driver:
> r30820 | neteler | 2008-03-30 20:23:55 +0100 (Sun, 30 Mar 2008) | 1 line
> added GDALLIBS for SASetupDefaultHooks
> You say that you're using r30825, and your link command has -lgdal, so
> it may be that you need a newer version of GDAL.
> Markus: is this change really necessary? Specifically, is the
> GDAL-isation actually necessary?
with 1.5.0b1 building dbf driver fails
/hardmnt/schiele0/ssi/landa/temp/grass_trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_shape.so:
I have upgraded GDAL to 1.6.0dev, then I was able to compile dbf driver.
Martin
> AFAICT, apart from some sanity checks in SHPReadObject(), the change
> is almost entirely down to using GDAL's custom I/O interface.
> I would have thought it would be better to just add the sanity checks
> and do without GDAL's I/O interface, particularly as the code can only
> ever use the default hooks (which presumably are just the stdio
> function).
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
