[GRASS-dev] new grass add-on
roberto.marzocchi
roberto.marzocchi at gmail.com
Fri May 2 03:58:18 EDT 2008
Reading the new version of
http://trac.osgeo.org/grass/wiki/HowToContribute I understand this:
I must write to you (currently you're the GRASS-PSC chair) and to other
developers. Only the grass developers or the GRASS-PSC chair can add my
"osgeo_id" to the OSGeo LDAP authentication system.
If I correctly understand, so is clear!!
An other suggest: You can write the e-mail address of grass developers
list too. Before I'm not sure that I must write to the grass developers
list for obtain the authentication of my "osgeo_id".
Cheers
Roberto
Markus Neteler ha scritto:
> Roberto,
> apparently the procedure is unclear.
> Please suggest how to make it clear!
> On Wed, Apr 30, 2008 at 4:17 PM, roberto.marzocchi
> <roberto.marzocchi a gmail.com> wrote:
>> Exactly, my userid (robertomarzocchi) isn't in the current list of members.
> This is the first time that we know it :)
>> Sorry, but I 've an other question....How can I communicate it to a
>> developer?
>> With this mailing list?
> OK, a valid question. I have updated
> to answer the question. Please read again and tell me if it is clear now.
> Sorry for using you as "caviar" but this is the best way to obtain a
> clear document!
> cheers
> Markus
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080502/6a37fb02/attachment-0001.html
