[GRASS-dev] new grass add-on
roberto.marzocchi
roberto.marzocchi at gmail.com
Fri May 2 08:46:17 EDT 2008
Markus Neteler ha scritto:
> hi Roberto,
> On Fri, May 2, 2008 at 9:58 AM, roberto.marzocchi
> <roberto.marzocchi a gmail.com> wrote:
>> Reading the new version of
>> http://trac.osgeo.org/grass/wiki/HowToContribute I understand this:
>> I must write to you (currently you're the GRASS-PSC chair) and to other
> Since we talk about the GRASS-SVN-Addons: to me *or* to another developer.
Yes, sorry I wanted to say "/or" /but I wrote "/and/"
>> developers. Only the grass developers or the GRASS-PSC chair can add my
>> "osgeo_id" to the OSGeo LDAP authentication system.
> Right.
>> If I correctly understand, so is clear!!
> Yes. I have polished wording again:
> http://trac.osgeo.org/grass/wiki/HowToContribute#ProceduretorequestGRASS-SVNwriteaccess
>> An other suggest: You can write the e-mail address of grass developers list
>> too.
> I think it is better to get into personal contact with a developer. The
> list is daily filled with messages, a request can easily get lost.
>> Before I'm not sure that I must write to the grass developers list for
>> obtain the authentication of my "osgeo_id".
> Do you think that the again modified Wiki page is clear now?
/"you may contact an active developer, see grass-dev mailing list archive"/
Very clear!
> BTW: 'robertomarzocchi' is now activated for GRASS-Addons-SVN.
> Please submit your script following the standards described in
> SUBMITTING_SCRIPTS
OK! I submit my script.
Do You made the update of the page
http://grass.osgeo.org/wiki/GRASS_AddOns or I must made something too?
Do you've received my mail with a version of the script for the next
releases of grass, three days ago?
There are some difference between the grass_addons directory! If You
didn't receive the mail, I may re-sent to you!
> (thanks for your patience - it actually helps to get the Wiki page
> clear also for other future contributors)
Thanks for /your/ patience!!!
> Happy hacking,
> Markus
cheers
Roberto
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080502/daeae882/attachment.html
