[GRASS-dev] order of tabs in r.colors in 6.4
    Martin Landa
    landa.martin at gmail.com
    Mon May  5 02:36:39 EDT 2008
2008/5/5 Hamish <hamish_b at yahoo.com>:
>  thanks Martin for reminding me about why the Required tab was needed, to
>  work around the "list $foo and exit" flag || map=required issue. As
>  earlier suggested by Glynn? we could fix that for next versions of GRASS
>  with a new flag->struct item which tells the parser not to worry about
>  testing all required options=. (and flags by definition can't be required
>  so as long as the flags are parsed first, it's do-able)
I have created a Trac ticket for that.
http://trac.osgeo.org/grass/ticket/156
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
