[GRASS-dev] Announcing libLAS
Hamish
hamish_b at yahoo.com
Mon May 5 22:18:10 EDT 2008
> I had in mind was to ask both of you to see how to make r.in.xyz read
> the LAS data directly (and maybe even run several of the statistics
> at once, if possible).
support for multiple method= and output= in the same run is a
long-standing wish for r.in.xyz, see the TODO section of the help page.
before doing anything, is there a LAS -> ascii .csv output tool that
sends the data to stdout? As a first easy step that command could be
piped directly into r.in.xyz, and I expect a wrapper script around that
would run at a speed fairly close to an integrated module. With that you
could hammer out the design of what is really needed for an integrated
module.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
