R: [GRASS-dev] v.in.e00 & AVCE00
Marco Pasetti
marco.pasetti at alice.it
Wed May 7 15:14:08 EDT 2008
Hi Markus,
>No reason, someone forgot to add it. I have done so now.
Perfect
>Since it was a technology preview, I suggest to wait.
Good.
>Let's do it for 6.3.1 or 6.4.0.
I'm going to open a ticket with 6.4.0 as milestone
>BTW: Maybe you better use VMAP0 instead of the older DCW (1992)...
>http://en.wikipedia.org/wiki/DCW
>http://en.wikipedia.org/wiki/Vector_Map
Thanks, as usual ;-)
Marco
-----Messaggio originale-----
Da: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] Per conto di
Markus Neteler
Inviato: mercoledì 7 maggio 2008 21.09
A: Marco Pasetti
Cc: GRASS Developer Mailing List
Oggetto: Re: [GRASS-dev] v.in.e00 & AVCE00
Hi Marco,
On Wed, May 7, 2008 at 8:45 PM, Marco Pasetti <marco.pasetti at alice.it>
wrote:
> Hi all,
> I was importing DCW (http://www.maproom.psu.edu/dcw/dcw_about.shtml)
> data with v.in.e00 (WinGRASS), but it reported the following error:
> 'avcimport' program not found, install it first;
> http://avce00.maptools.org
> this requirement is not present in the GRASS requirements list, why?
> BTW, I visited the suggested web page and downloaded the source code;
> I will compile it on next hour.
> If it will work fine, should we update the WinGRASS binary release
> now (that is when I compiled and tested it) or can we wait for the next
GRASS release?
> Update means: update the binaries (installer), the files
> WinGRASS_Sources.zip, GRASS_MSYS_Environment.zip and the
> BuilFromSource guide.
> Comments?
Markus
