[GRASS-dev] v.in.e00 & AVCE00
Markus Neteler
neteler at osgeo.org
Wed May 7 15:08:48 EDT 2008
Hi Marco,
On Wed, May 7, 2008 at 8:45 PM, Marco Pasetti <marco.pasetti at alice.it> wrote:
> Hi all,
> I was importing DCW (http://www.maproom.psu.edu/dcw/dcw_about.shtml) data
> with v.in.e00 (WinGRASS), but it reported the following error:
> 'avcimport' program not found, install it first;
> http://avce00.maptools.org
> this requirement is not present in the GRASS requirements list, why?
No reason, someone forgot to add it. I have done so now.
> BTW, I visited the suggested web page and downloaded the source code; I will
> compile it on next hour.
> If it will work fine, should we update the WinGRASS binary release now (that
> is when I compiled and tested it) or can we wait for the next GRASS release?
Since it was a technology preview, I suggest to wait.
> Update means: update the binaries (installer), the files
> WinGRASS_Sources.zip, GRASS_MSYS_Environment.zip and the BuilFromSource
> guide.
> Comments?
Let's do it for 6.3.1 or 6.4.0.
BTW: Maybe you better use VMAP0 instead of the older DCW (1992)...
http://en.wikipedia.org/wiki/DCW
http://en.wikipedia.org/wiki/Vector_Map
Markus
