R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sat May 10 06:11:16 EDT 2008
On Fri, 9 May 2008 marco.pasetti at alice.it wrote:
> Hi all,
> I also tried to launch GRASS with GISBase without spaces (such as C:\GISBASE), with the demolocation, and placing the input file (Z_39_3.ASC) in a path without spaces too (C:\), but I got the same result.
Hello Marco,
How big is the file? Would it be possible to put it somewhere for me to
have a look at and try and reproduce the behaviour?
FWIW, other things to try would be to see if other commands can read the
projection info from the file. E.g.
gdalinfo filename
g.proj -p georef=filename
Paul
