R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
marco.pasetti at alice.it
Mon May 12 04:09:27 EDT 2008
Hi Glynn,
In PERMANENT I have WIND and DEFAULT_WIND; they have Unix line endings.
PROJ_* files are missing!
Many thanks
Marco
Da: Glynn Clements [mailto:glynn at gclements.plus.com]
Inviato: dom 11/05/2008 7.12
A: marco.pasetti at alice.it
Cc: grass-dev at lists.osgeo.org
Oggetto: Re: [GRASS-dev] WinGRASS: r.in.gdal projection issue
marco.pasetti at alice.it wrote:
> During WinGRASS 6.3.0 testings I encontered a problem with the r.in.gdal
> module: it reports no errors, and correctly import rasters, but fails
> creating the projection for the new location created during raster
> import.
> I explain better with an example: I imported an SRTM tile, to be
> imported in a new location named "test", with the following command
> line:
> r.in.gdal {input=C:/Documents and Settings/Marco/Documenti/GIS Data
> Repository/SRTM v3.0 DEM 90m/Z_39_3.ASC} output=Z_39_3.dem
> location=test
> At the end of the Run it reports as follows in the output window:
> Location <test> created
> r.in.gdal complete.
> After that I exit GRASS and I restart it accessing the location test:
> the raster have been correctly imported, the region set to the raster
> boundaries, but if type:
> g.proj -j
> it reports
> XY (unprojected)
> talking in IRC with a linux huy, I asked him to do the same command
> using the same raster with GRASS-6.3.0SVN: the location test, for him,
> has a correct projection (that is latlong wgs84 and so on...). So I
> guess that is a windows problem, but I don't really know why since the
> command doesn't report errors!
> any suggestions?
Check the existence and contents of the following:
<database>/test/
<database>/test/PERMANENT/
<database>/test/PERMANENT/DEFAULT_WIND
<database>/test/PERMANENT/PROJ_INFO
<database>/test/PERMANENT/PROJ_UNITS
where <database> is the GRASS database directory.
In particular, check whether the files have Unix (LF) or DOS (CR+LF)
line endings (if the files look correct in Notepad, they have DOS line
endings; with Unix line endings, you get one long line with little
black blocks).
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080512/68be37db/attachment.html
