R: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
marco.pasetti at alice.it
Mon May 12 10:55:41 EDT 2008
Hi Paul,
I agree. Did you try to import the file with GRASS on linux?
Thanks
Marco
Da: Paul Kelly [mailto:paul-grass at stjohnspoint.co.uk]
Inviato: lun 12/05/2008 16.42
A: Michael Barton
Cc: marco.pasetti at alice.it; grass-dev at lists.osgeo.org
Oggetto: Re: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
On Mon, 12 May 2008, Michael Barton wrote:
> Marco,
> In most (all?) cases with my students, the problem locations were made by
> picking an EPSG code. This routine uses g.proj to create the location. The
> same issue may be affecting r.in.gdal I suppose.
Hello Michael, I seem to remember committing a fix for what I guessed was
your problem with the EPSG codes - has there been any incidence of it
since then? Marco's problem is clearly different as the gdalinfo output
shows that GDAL is not recognising any projection information from the
file, so creating an XY location is the correct behaviour.
Paul
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080512/c232e53b/attachment.html
