[GRASS-dev] Re: [GRASS GIS] #127: WinGRASS Tcl/Tk GUI - Text
formatting error in Output window
Glynn Clements
glynn at gclements.plus.com
Thu May 15 20:08:59 EDT 2008
Michael Barton wrote:
> > #127: WinGRASS Tcl/Tk GUI - Text formatting error in Output window
> > Reporter: 4everskiff | Owner: grass-dev at lists.osgeo.org
> > Type: defect | Status: new
> > Priority: minor | Milestone: 6.4.0
> > Component: Tcl | Version: 6.3.0
> > Resolution: | Keywords: Text output, winGRASS
> > Changes (by marcopx):
> > * version: 6.3.0 RCs => 6.3.0
> > Comment:
> > Replying to [comment:5 cmbarton]:
> >> I've committed a change to gronsole.tcl that I hope fixes this. It is
> > not a problem on the Mac, and maybe only on Windows. I moved the linefeed
> > for command output text from after the text line to before the text line.
> > I'm assuming that Windows will read "\n" as a line feed. Could someone
> > please test in Windows. I'm not changing this ticket to resolved yet to
> > see if it actually works.
> >> Michael
> > Very good.
> > It seems that I definetly need to build upon the SVN trunk. It will take 3
> > hours or more here :-(
> > BTW, the windows (working) code for the Carriage Return & Linefeed is
> > \r\n, but probably the \n suffices
> This may be the underlying cause of the error in gronsole.tcl. I don't know
> how /r is read in *nix. I'm also not sure if I can get away with replacing
> "/n" with a variable so that I can make it vary by platform. E.g.,
> If {$mingw == 1} {set rlf {/r/n}} else {set rlf {/n}}
First, the escape character is a backslash, not a (forward) slash.
Tcl/Tk behaves like C, in that \n is used as the line separator
internally. \r characters should be added/removed upon output/input.
In particular, if you want to add a line break within a multi-line
text widget, you just add a \n character regardless of platform.
To handle EOL conversions for I/O, use "fconfigure ... -translation ...".
