[GRASS-dev] Re: [GRASS GIS] #127: WinGRASS Tcl/Tk GUI - Text
formatting error in Output window
Michael Barton
michael.barton at asu.edu
Thu May 15 20:38:46 EDT 2008
Thanks for the suggestions.
Michael
On 5/15/08 5:08 PM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>>> #127: WinGRASS Tcl/Tk GUI - Text formatting error in Output window
>>> Reporter: 4everskiff | Owner: grass-dev at lists.osgeo.org
>>> Type: defect | Status: new
>>> Priority: minor | Milestone: 6.4.0
>>> Component: Tcl | Version: 6.3.0
>>> Resolution: | Keywords: Text output, winGRASS
>>> Changes (by marcopx):
>>> * version: 6.3.0 RCs => 6.3.0
>>> Comment:
>>> Replying to [comment:5 cmbarton]:
>>>> I've committed a change to gronsole.tcl that I hope fixes this. It is
>>> not a problem on the Mac, and maybe only on Windows. I moved the linefeed
>>> for command output text from after the text line to before the text line.
>>> I'm assuming that Windows will read "\n" as a line feed. Could someone
>>> please test in Windows. I'm not changing this ticket to resolved yet to
>>> see if it actually works.
>>>> Michael
>>> Very good.
>>> It seems that I definetly need to build upon the SVN trunk. It will take 3
>>> hours or more here :-(
>>> BTW, the windows (working) code for the Carriage Return & Linefeed is
>>> \r\n, but probably the \n suffices
>> This may be the underlying cause of the error in gronsole.tcl. I don't know
>> how /r is read in *nix. I'm also not sure if I can get away with replacing
>> "/n" with a variable so that I can make it vary by platform. E.g.,
>> If {$mingw == 1} {set rlf {/r/n}} else {set rlf {/n}}
> First, the escape character is a backslash, not a (forward) slash.
> Tcl/Tk behaves like C, in that \n is used as the line separator
> internally. \r characters should be added/removed upon output/input.
> In particular, if you want to add a line break within a multi-line
> text widget, you just add a \n character regardless of platform.
> To handle EOL conversions for I/O, use "fconfigure ... -translation ...".
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
