[GRASS-dev] Changes which may need to be merged
Markus Neteler
neteler at osgeo.org
Wed May 21 04:39:18 EDT 2008
On Wed, May 21, 2008 at 10:09 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> The following files currently differ between develbranch_6 and the
> trunk, for no obvious reason:
> doc/howto_release.txt
> lib/proj/projlib.dox
> vector/v.db.select/description.html
> vector/v.db.select/main.c
... above sync'ed.
> general/g.region/main.c
No need to backport.
The following I didn't check (not my field):
> gui/tcltk/gis.m/gm.tcl
> gui/tcltk/gis.m/gmlib.tcl
> gui/tcltk/gis.m/mapcanvas.tcl
> gui/tcltk/gis.m/runandoutput.tcl
> lib/gis/gui.tcl
> lib/gtcltk/gronsole.tcl
> scripts/d.split/d.split
> scripts/d.split/description.html
> vector/v.label.sa/labels.c
> Can whoever made the changes check whether these should be merged?
Markus
