[GRASS-dev] Changes which may need to be merged
Hamish
hamish_b at yahoo.com
Wed May 21 06:24:29 EDT 2008
> The following files currently differ between develbranch_6
> and the trunk, for no obvious reason:
> scripts/d.split/d.split
> scripts/d.split/description.html
> Can whoever made the changes check whether these should be
> merged?
I have replaced d.split in grass7 with the d.frame.split script from grass-addons. It is much better but the options are not backwards compatible, so not backported to develbranch_6.
Hamish
