R: R: [GRASS-dev] Locking is not supported on Windows
marco.pasetti at alice.it
Wed May 21 10:20:59 EDT 2008
Hi Glynn,
>Right. But in that case, it should fail with "Unable to read GIS_LOCK
enviroment variable".
as it does
>g.gisenv will definitely work, at least for the command line
no, afraid. I also tried with the msys shell (after starting GRASS); for example, with GRASS opened with the demolocation (PERMANENT):
g.gisenv --v set="LOCATION_NAME=GRASS-Tutorial"
it reports nothing as output, and the location is still the same.
Marco
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080521/36e02dd1/attachment-0001.html
