[GRASS-dev] Re: [GRASS GIS] #171: d.vect: -c type=area doesn't draw boundary
GRASS GIS trac at osgeo.org
Fri May 23 15:08:41 EDT 2008
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:  d.vect
Comment (by neuba):
 Hi I don't know it is the same issue but I can not draw any vector map
 with d.vect when I use command like d.vect output=map1 i got this error
 message: output <map1> exist. If I put an inexistant vector, I got: map
 <map1> not found.
 Thank you
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:3>
