[GRASS-dev] Re: [GRASS GIS] #171: d.vect: -c type=area doesn't draw
boundary
trac at osgeo.org
Fri May 23 15:20:21 EDT 2008
#171: d.vect: -c type=area doesn't draw boundary
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: d.vect
Comment (by martinl):
Replying to [comment:3 neuba]:
> Hi I don't know it is the same issue but I can not draw any vector map
with d.vect when I use command like d.vect output=map1 i got this error
message: output <map1> exist. If I put an inexistant vector, I got: map
<map1> not found.
There is no 'output' parameter
d.vect --help
d.vect output=x
Sorry, <output> is not a valid parameter
ERROR: Required parameter <map> not set:
(Name of input vector map).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:4>
