[GRASS-dev] Re: [GRASS GIS] #171: d.vect: -c type=area doesn't draw
boundary
trac at osgeo.org
Fri May 23 16:43:21 EDT 2008
#171: d.vect: -c type=area doesn't draw boundary
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: d.vect
Comment (by neteler):
Replying to [comment:3 neuba]:
> Hi I don't know it is the same issue but I can not draw any vector map
with d.vect when I use command like d.vect output=map1 ...
IMPORTANT to all SVN users:
After the recent change in parser.c you need to RECOMPILE GRASS from
scratch.
I wanted to post this but forgot about it. So
make distclean
sh configure ...
make
to get the parameters right again.
@neuba: this is unrelated to this bug report.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:5>
