[GRASS-dev] G_OPT_* constants
Glynn Clements
glynn at gclements.plus.com
Sat May 24 05:10:00 EDT 2008
GRASS GIS wrote:
> IMPORTANT to all SVN users:
> After the recent change in parser.c you need to RECOMPILE GRASS from
> scratch.
> I wanted to post this but forgot about it. So
> make distclean
> sh configure ...
> make
Might it be better to just assign explicit values to the G_OPT_*
constants, so that this issue doesn't occur whenever new constants are
added or removed?
A related, but distinct option is to make e.g. G_gisinit() check that
the library and module were compiled with the same version of gis.h,
I.e.:
include/gis.h:
int G__gisinit(const char *, const char *);
#define GIS_H_VERSION "$Revision$"
#define G_gisint(pgm) G__gisinit(GIS_H_VERSION, (pgm))
lib/gis/gisinit.c:
int G__gisinit(const char *version, const char *pgm)
if (strcmp(version, GIS_H_VERSION) != 0)
G_fatal_error(_("Incompatible library version for module"));
