[GRASS-dev] Re: [GRASS GIS] #354: v.out.ogr: bad DB read for
format=GPX
trac at osgeo.org
Sun Nov 2 06:49:37 EST 2008
#354: v.out.ogr: bad DB read for format=GPX
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: v.out.ogr GPX
Platform: Linux | Cpu: x86-32
Comment (by hamish):
Replying to [comment:3 hamish]:
> It appears that ogr2ogr isn't applying the given +nadgrid file.
Correct, first google hit for ogr2ogr+nadgrids gave the answer: for
ogr2ogr you need to append +wktext to the input SRS. Then it works.
http://lists.osgeo.org/pipermail/gdal-dev/2007-April/012561.html
Is this an issue for the R-GRASS interface?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/354#comment:4>
