[GRASS-dev] Re: [GRASS GIS] #354: v.out.ogr: bad DB read for
format=GPX
trac at osgeo.org
Tue Nov 4 02:05:48 EST 2008
#354: v.out.ogr: bad DB read for format=GPX
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: v.out.ogr GPX
Platform: Linux | Cpu: x86-32
Comment (by hamish):
back to original issue,
this is a followup to #2638,
https://trac.osgeo.org/gdal/ticket/2638#comment:1
cross-filed as GDAL bug # 2653
https://trac.osgeo.org/gdal/ticket/2653
data intended for <extensions> is filling standard GPX fields
instead.
Exporting a points feature map as GPX:
(GRASS's North Carolina sample dataset)
# export GRASS points map as GPX format
GRASS64> v.out.ogr in=hospitals dsn=hsp.gpx format=GPX type=point \
dsco="GPX_USE_EXTENSIONS=YES"
GRASS64> v.info -c hospitals
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|OBJECTID
DOUBLE PRECISION|AREA
DOUBLE PRECISION|PERIMETER
INTEGER|HLS_
INTEGER|HLS_ID
CHARACTER|NAME
CHARACTER|ADDRESS
CHARACTER|CITY
CHARACTER|ZIP
CHARACTER|COUNTY
CHARACTER|PHONE
CHARACTER|CANCER
INTEGER|POLYGONID
DOUBLE PRECISION|SCALE
DOUBLE PRECISION|ANGLE
# SQL: select * FROM hospitals ...
GRASS64> v.db.select hospitals | head -n 4
cat|OBJECTID|AREA|PERIMETER|HLS_|HLS_ID|NAME|ADDRESS|CITY|ZIP|COUNTY|PHONE|CANCER|POLYGONID|SCALE|ANGLE
1|1|0|0|1|1|Cherry Hospital|400 Stevens Mill
Rd|Goldsboro|27533|Wayne|(919) 731-3200|yes|0|1|1
2|2|0|0|2|2|Wayne Memorial Hospital|2700 Wayne Memorial
Dr|Goldsboro|27534|Wayne|(919) 736-1110|yes|0|1|1
3|3|0|0|3|3|Watauga Medical Center|336 Deerfield
Rd|Boone|28607|Watauga|(828) 262-4100|yes|0|1|1
$ cat hsp.gpx
<?xml version="1.0"?>
<gpx version="1.1" creator="GDAL 1.5.0" xmlns:xsi="http://www.w3.org/2001/
XMLSchema-instance" xmlns:ogr="http://osgeo.org/gdal" xmlns="http:
//www.topografix.com/GPX/1/1"
xsi:schemaLocation="http://www.topografix.com/GPX/1/1
http://www.topografix.com/GPX/1/1/gpx.xsd">
<wpt lat="182012.655400562332943" lon="697237.563861500239000">
<ele>1</ele>
<magvar>0</magvar>
<geoidheight>0</geoidheight>
<name>1</name>
<cmt>1</cmt>
<desc>Cherry Hospital</desc>
<src>400 Stevens Mill Rd</src>
<link href="Goldsboro"><text>27533</text><type>Wayne</type></link>
<link href="(919) 731-3200"><text>yes</text><type>0</type></link>
<sym>1</sym>
<type>1</type>
<extensions>
</extensions>
</wpt>
<wpt lat="183568.906400562496856" lon="704563.187861500075087">
<ele>2</ele>
<magvar>0</magvar>
<name>2</name>
<cmt>2</cmt>
<desc>Wayne Memorial Hospital</desc>
<src>2700 Wayne Memorial Dr</src>
<link href="Goldsboro"><text>27534</text><type>Wayne</type></link>
<link href="(919) 736-1110"><text>yes</text><type>0</type></link>
<sym>1</sym>
<type>1</type>
<extensions>
</extensions>
</wpt>
<wpt lat="274897.219400562578812" lon="371094.156861500116065">
<ele>3</ele>
<magvar>0</magvar>
<name>3</name>
<cmt>3</cmt>
<desc>Watauga Medical Center</desc>
<src>336 Deerfield Rd</src>
<link href="Boone"><text>28607</text><type>Watauga</type></link>
<link href="(828) 262-4100"><text>yes</text><type>0</type></link>
<sym>1</sym>
<type>1</type>
<extensions>
</extensions>
</wpt>
the "cat" field will always be present regardless of if the map has an
attached attribute DB or not. (i.e. a key INTEGER db field will always be
present, and by default this is named "cat")
AFAICT if there is no attribute DB attached to the map the key field (eg
"cat") should be used for <name> in the GPX file.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/354#comment:5>
