[GRASS-dev] grass 6.3, wxpython, g.parser
Jachym Cepicky
jachym.cepicky at gmail.com
Tue Nov 4 02:34:39 EST 2008
2008/11/1 Glynn Clements <glynn at gclements.plus.com>:
> Jachym Cepicky wrote:
>> just compiled the GRASS 6.3 at ubuntu 8.10, there is a problem with the wx-gui:
>> $ grass63 -wxpython
>> GRASS>
>> # try to add raster layer to map, int the command line, I get:
>> *** buffer overflow detected ***: g.parser terminated
> This doesn't actually look like a wxgui issue, but an issue with
> g.parser. It would help if you could figure out which script is
> triggering this.
sorry,
it appears, when I try to add raster map to monitor, the error
popusup, right before the "d.rast [display]" window, for raster map
name selection, is rendered. when I try to pick one map from the the
list of layers,
only mapsets are listed, but no maps
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
