[GRASS-dev] grass 6.3, wxpython, g.parser
Sat Nov 1 01:51:41 EDT 2008
Jachym Cepicky wrote:
> just compiled the GRASS 6.3 at ubuntu 8.10, there is a problem with the wx-gui:
> $ grass63 -wxpython
> GRASS>
> # try to add raster layer to map, int the command line, I get:
> *** buffer overflow detected ***: g.parser terminated
This doesn't actually look like a wxgui issue, but an issue with
g.parser. It would help if you could figure out which script is
triggering this.
