[GRASS-dev] Re: [GRASS GIS] #352: r.in.gdal region troubles in LL
GRASS GIS trac at osgeo.org
Sat Nov 1 01:48:57 EDT 2008
  Reporter:  neteler      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:2 neteler]:
 > The user took this map
 > and passed it to R, and then redefined:
 > and then he wrote b as npp.tif using the QGIS plugin manageR.
 > Maybe there is a precision issue before, somwhere in the R or QGIS part?
 It appears so. The inaccuracy is present in the TIFF file; it isn't being
 introduced by libtiff, GDAL or GRASS.
 I'm not quite sure where it would come from; 1/4 is exactly representable
 in single-precision floating-point. My first guess would be something
 calculating 360*(1/1440) rather than 360/1440 (1/1440 isn't exactly
 representable). This can occur if code is compiled with -funsafe-math-
 optimizations or similar.
 In any case, there's still the issue that GRASS takes a lat/lon region
 which is actually 360.000000000288 degrees across and treats it as if it's
 0.000000000288 degrees across. Wrapping coordinates is one thing; wrapping
 intervals is something else entirely.
 Ultimately, you can't take algorithms which work for Euclidian geometry
 and make them work for spherical geometry with nothing more than a couple
 of quick hacks.
 On a related note, I still haven't got anywhere with the "r.resamp.stats:
 nulls along western boundary" issue reported by Hamish (this should
 probably be added as a ticket).
Ticket URL: <http://trac.osgeo.org/grass/ticket/352#comment:3>
