[GRASS-dev] Re: [GRASS GIS] #355: ps.map generates invalid postscript when vlegend item does not appear on map
GRASS GIS trac at osgeo.org
Wed Nov 5 03:38:55 EST 2008
map
  Reporter:  scottygamm        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect            |      Status:  new
  Priority:  minor             |   Milestone:  6.3.1
 Component:  default           |     Version:  6.3.0
Resolution:                    |    Keywords:
  Platform:  MSWindows CygWin  |         Cpu:  x86-32
Comment (by neteler):
 Replying to [ticket:355 scottygamm]:
 On Tue, Nov 4, 2008 at 4:16 PM, Bob Covill <bcovill tekmap ns.ca> wrote:
 I encountered the same problem a couple of weeks ago. I was able to get
 around it by adding the following to ps_vlegend.c around line 172 ...
   pat_save ( PS.fp, vector.layer[i].pat, pat);
 Insert this line after
 sprintf ( pat, "APATTEPS%d", i);
 to ensure the pattern definition is saved.
 Hope this helps.
 Bob
Ticket URL: <http://trac.osgeo.org/grass/ticket/355#comment:1>
