[GRASS-dev] [GRASS GIS] #355: ps.map generates invalid postscript when vlegend item does not appear on map
Bob Covill bcovill at tekmap.ns.ca
Tue Nov 4 10:16:02 EST 2008
I encountered the same problem a couple of weeks ago. I was able to get
around it by adding the following to ps_vlegend.c around line 172 ...
pat_save ( PS.fp, vector.layer[i].pat, pat);
Insert this line after "sprintf ( pat, "APATTEPS%d", i);" to ensure the
pattern definition is saved.
Hope this helps.
Bob
> map
>  Reporter:  scottygamm  |       Owner:  grass-dev at lists.osgeo.org
>      Type:  defect      |      Status:  new
>  Priority:  minor       |   Milestone:  6.3.1
> Component:  default     |     Version:  6.3.0
>  Keywords:              |    Platform:  MSWindows CygWin
>       Cpu:  x86-32      |
>  I have a map control file that generates several (21) vareas with pattern
>  fill and defines label and lpos entries for the legend.  As it happens,
>  one of those vareas does not appear on the map area.  As a result, the
>  postscript output omits the dictionary entry for that pattern.  When
>  vlegend generates the legend output, it attempts to reference the missing
>  pattern definition (of the form APATTEPSnn) and applications that try to
>  render the postscript fail in various ways.  Workaround is to omit the
>  vareas causing the problem.  I have not included files but can provide
>  them if needed.
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
