[GRASS-dev] wrong configure documentation for compilation with
wxwidgets ?
Moritz Lennert
mlennert at club.worldonline.be
Wed Nov 5 03:55:23 EST 2008
Below discussion comes from the DebianGIS mailing list. It raises an
issue about documentation of the configure options.
./configure --help shows:
--with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config
with path, e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)
but this does not seem to work, while below solution does. Looking
through the configure file, I don't really understand why this is so
(but then again, I can't claim that I understand everything in that file).
So, is the documentation wrong, or does below solution just work by chance ?
Moritz
-------- Original Message --------
Subject: Re: [DebianGIS] testing Debian build of GRASS 6.4 SVN
Date: Tue, 04 Nov 2008 20:13:28 -0600
Organization: Church of Emacs
To: pkg-grass-general at lists.alioth.debian.org
On Tue, 04 Nov 2008 17:16:26 +0100,
Moritz Lennert <mlennert at club.worldonline.be> wrote:
> On 05/11/08 03:13, Seb wrote:
>> Yes, I liked that better too. However, modifying that target as:
>> ,-----[ rules (lines: 66 - 67) ]
>> | --with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
> It should be:
> --with-wx=/usr/lib/wx/config/gtk2-unicode-release-2.8\
> --with-wxwidgets \
Yes, this worked. The packages built fine. The only problem reamining
is the clash betwee grass-preview-doc and grass-doc I posted earlier.
Thanks everyone for your help.
