[GRASS-dev] wrong configure documentation for compilation with
wxwidgets ?
Martin Landa
landa.martin at gmail.com
Wed Nov 5 08:41:52 EST 2008
2008/11/5 Moritz Lennert <mlennert at club.worldonline.be>:
> Below discussion comes from the DebianGIS mailing list. It raises an issue
> about documentation of the configure options.
> ./configure --help shows:
> --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with
> path, e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)
> but this does not seem to work, while below solution does. Looking through
> the configure file, I don't really understand why this is so (but then
> again, I can't claim that I understand everything in that file).
> So, is the documentation wrong, or does below solution just work by chance ?
> On Tue, 04 Nov 2008 17:16:26 +0100,
> Moritz Lennert <mlennert at club.worldonline.be> wrote:
>> On 05/11/08 03:13, Seb wrote:
>>> Yes, I liked that better too. However, modifying that target as:
>>> ,-----[ rules (lines: 66 - 67) ]
>>> --with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
>> It should be:
>> --with-wx=/usr/lib/wx/config/gtk2-unicode-release-2.8\
>> --with-wxwidgets \
> Yes, this worked. The packages built fine. The only problem reamining
> is the clash betwee grass-preview-doc and grass-doc I posted earlier.
> Thanks everyone for your help.
there is no --with-wx just --with-wxwidgets which takes as argument
*path to wx-config* (similary e.g. to --with-gdal)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
