[GRASS-dev] Re: [GRASS GIS] #354: v.out.ogr: bad DB read for format=GPX
GRASS GIS trac at osgeo.org
Thu Nov 6 08:28:48 EST 2008
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Vector  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  v.out.ogr GPX
  Platform:  Linux   |         Cpu:  x86-32
Comment (by hamish):
 yes, that would seem to be the case: "j" is used as Field, it assumes OGR
 fields use the same index as grass column order:
 https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.out.ogr/main.c#L705
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/354#comment:7>
